Sold FS: DLS A7 mint condition Amp.
h180ss
I just bought this amp couple week ago from mobeious member of diymobileaudio. It is working perfectly and there's nothing wrong with this amp. The reason I am selling this amp because I just got a new T03-4 Amp and I dont need A7 anymore. It's an authentic from Dealer. Retails at $975.00
Give me the best offer to h180ss@yahoo.com
Number of channels 5
Amplifier class AB
Output power in 4 ohm 4 x 60 W
Output power in 2 ohm 4 x 100 W
Mono bridge mode 4 ohm 2 x 200 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 440 W
Mono sub channel output in 1 ohm 600 W
Frequency range 10 Hz - 50 kHz
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,3 - 7 V
Input impedance > 10 kohm
Filters channel A & B HP: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filters channel C & D HP: 80 - 400 Hz. LP: 0,3 - 4 kHz / 3 - 40 kHz (x10)
External cooling fan terminal 1
Remote base level control 1
Remote phase shift control 1
Power consumption (idle) 1,1A
Power consumption (max) 120 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 35 A + 2 x 20 A
Dimension (W x D x H) 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inches)
Weight 8,1 kg ( 17,86 lb)
http://i291.photobucket.com/albums/ll302/h180ss/Picture-2.jpg
http://i291.photobucket.com/albums/ll302/h180ss/Picture003-15.jpg
http://i291.photobucket.com/albums/ll302/h180ss/Picture002-19.jpg
http://i291.photobucket.com/albums/ll302/h180ss/Picture001-16.jpg
Thanks,
Edwin
just remember to show some references for yourself, or link to references from other sites that you can confirm, to make sure people will be comfortable dealing with you.
good luck
good luck
Thank you for your concern. I have account in Ebay too which have 100% good feedback too, member since 2001. (edwinliem)
h180ss
h180ss
Seattle,WA
hemi4me?
