I will combine shipping costs on multiple items. And items will be packed VERY well.
As far as trades, I am ONLY interested in
• Scan Speak 18W/8535, 18W/8545, or 18W/8545K 7" woofers
• Sundown Audio SAX-100.4 or Arc Audio KS 300.4
Peerless 831882 Exclusive 5.75" woofers
The woofers are used but in perfect condition. They are considered one of the best midrange drivers available.
• Znom 8 ohm
• Re 5.9 ohm
• Le 0.8 mH
• fs 64.5 Hz
• Qms 3.85
• Qes 0.43
• Qts 0.39
• Mms 8.8 g
• Cms 0.69 mm/N
• Sd 87 cm2
• BL 7.0 N/A
• Vas 7.2 ltrs
• Xmax 3.5 mm peak
SOLD
ESX Quantum Q120.4 Amplifier
Super rare Zed made amplifier that has a multitude of crossover and power options. It is the only amplifier/processor you need to run a 2-way active system. It's not very pretty but works 100%. I will include the manual because you WILL need it.
Output Power at 12V:
• 4 x 120W @ 4 ohms
• 4 x 180W @ 2 ohms
• 2 x 240W @ 8 ohms bridged
• 2 x 360W @ 4 ohms bridged
• 2 x 150W @ 4 ohms bridged "TRUE MONO"
• 2 x 240W @ 2 ohms bridged "TRUE MONO"
• 2 x 360W @ 1 ohm bridged "TRUE MONO"
• 2 x 250W @ 4 ohms bridged "TRUE MONO / HIGH VOLTAGE"
• 2 x 400W @ 2 ohms bridged "TRUE MONO / HIGH VOLTAGE"
• 1 x 300W @ 8 ohms "MONOBLOCK"
• 1 x 500W @ 4 ohms "MONOBLOCK"
• 1 x 720W @ 2 ohms "MONOBLOCK"
• 1 x 500W @ 8 ohms "MONOBLOCK / HIGH VOLTAGE"
• 1 x 800W @ 4 ohms "MONOBLOCK / HIGH VOLTAGE"
$390 shipped
Lunar L40x2 Amplifier
These are super small amplifiers and generally put out about 20% more then their rating. You can contact Lunar and have them modified and are considered to be "sound quality" amplifiers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. The L40x2 has been benched at 60x2. Again not pretty but works 100%.
• Class A/B
• 4 Ohm Stereo= 40watts x 2 (benched 60 watts x 2)
• 2 Ohm Stereo= 90watts x 2
• 4 Ohm Mono= 180watts x 1
• 2 Ohm Mono= Not Recommended
• Over Current Shut Down
• Over Temperature Shut Down
• Left and Right Gain Controls
• Left and Right Bass Controls
• Fuse: 30 amp
• Dimensions: 9.5” x 5” x 3”
SOLD
Alumapro Aluminum Tweeters
These tweeters are from the ALC component series. Exmaxima1 told be they are very similar to the Rainbow Cal25. They should work after they are glued back together.
$30 shipped
Zapco built BSG 6 Channel Amplifier
6 channels 30W per at 4 ohms. 1-4 are HP'd 5-6 are LP'd at the control unit, the control unit has volume, bass, treble, mic gain and ducking. You can follow chad's instructions and have an un-preamped, bridgable 6 channel home amplifier. All of the paper work and cords are included. I will throw in a free heavy duty power cord.
SOLD
• Znom 8 ohm
• Re 5.9 ohm
• Le 0.8 mH
• fs 64.5 Hz
• Qms 3.85
• Qes 0.43
• Qts 0.39
• Mms 8.8 g
• Cms 0.69 mm/N
• Sd 87 cm2
• BL 7.0 N/A
• Vas 7.2 ltrs
• Xmax 3.5 mm peak
SOLD
• 4 x 120W @ 4 ohms
• 4 x 180W @ 2 ohms
$390 shipped
• Class A/B
• Fuse: 30 amp
SOLD
$30 shipped
SOLD
