Sold FS: DLS A5 "Big Three"
JoeHemi57
Asking $350 shipped, great sq amp for passive components + sub
Mode: AB
Number of channels: 3
Nominal power in 4 ohm: 2 x 50 W
Typical power in 4 ohm: 2 x 85 W
Typical power in 2 ohm: 2 x 100 W
Mono channel, nominal power in 4 ohm: 300 W
Mono channel, nominal power in 2 ohm: 500 W
S / N ratio, A-weighted: > 100 dB
Damping factor: > 200
Input impedance: > 10 kohm
Input sensitivity, variable: 0,2 - 7 V
Filter, front channels: Highpass: 50-125 Hz
Filter, mono channel: Lowpass: 40-90 Hz. Subsonic: 25 Hz
Terminal for external cooling fan: Yes
Dual DC-inputs: No
Current draw, idle: 0,5 A
Current draw, maximum: 90 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight: 6,6 kg ( 14,55 lb)
Amp is 1ohm stable on the sub channel and makes 780w
JoeHemi57
JoeHemi57
Little Rock, Arkansas
JoeHemi57
