Sold FS: DLS A3 Twin Mono
Colin+M
Hey guys, I'm moving this one out to make room for an A5. Other wise it wouldn't be going anywhere.
I am the second owner, originally purchased from Mark Brooks (auth. DLS dealer).
It has been installed for about 2 weeks alongside my A4:D
No this isn't a fake, and yes I would know.
Includes box, manual, plastic bag etc.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 2
Nominal power in 4 ohm : 2 x 100 Watt
Typical power in 4 ohm : 2 x 150 watt
Typical power in 2 ohm : 2 x 270 Watt
Typical power in 1 ohm : 2 x 425 Watt
Typical power in 4 ohm bridge mode : 550 Watt
Typical power in 2 ohm bridge mode : 870 Watt
Typical power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight
: 6,2 kg ( 13,67 lb)
Retail $800
I am asking $350
Colin+M
Colin+M
small town, AL
Colin+M
