Sold fs crunch/ma audio/stinger
169db
up for sale today is my old system
ma audio hk-602sx amp
Specs as follows:
400W RMS X 2 @ 4 Ohm
700W RMS X 2 @ 2 Ohm
200W RMS X 2 @ 1 Ohm
1800W RMS X 2 @ 0.5
3600W RMS X 1 @ 1 Ohm
Frequency Response: 20-20kHz
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
0-18 dB Variable Bass Boost
S/N Ratio: >90dB
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
High Quality Power & Protection LED’s
Quiet Fan Cooling System (I can replace the fan with an upgrade for an additional charge)
Thermal / Short / Overload Protection Circuitry
Remote Bass Terminal
the amp is in good condition i give it 6.5 out of 10 and
10/10 mechanical
next up is stinger spv70 cosmetical condition 8,5 out of 10 and mechanical i give it a 10 out 10 sits at 12.3 volts
last i have crunch gp4150 4 channel amp cosmetical condition 8 out of 10 mechanical 10 out of 10
ma amp 355 shipped
stinger battery 135 shipper
crunch amp 85 shipped
1200W 2 / 3 / 4-Channel A/B Class Amplifier
150W x 4-Ch @ 4-Ohms
300W x 4-Ch @ 2-Ohms
600W x 2-Ch @ 4-Ohms Dynamic Music Watts
Ultra-Clean A/B-Class HQ Amplifier Designs
configure into 3-Ch Mode for R & L and Sub
Bridgeable Designs
Dual-Core MOSFET Power Supply Design
High-Grade MOSFET Audio Outputs
Remote Bass Control Included
Amp Protection with Diagnostics LED's
Dual Sound Shaping Controls
12 dB Bass Boost
Mono/Stereo Switch
HP/LP/Full-Pass Crossover Selections
Crossover Frequency Adjustments: 50Hz to 250Hz
Input Level Control 0.2-5V
RCA Inputs & Line Outputs
Removable Amplifier End Caps
169db
169db
birdville
169db
NorthFramingham
    Jun 30, 2026
