Super clean little mono amp. Comes with bass knob and wire. Small footprint.
- Maximum Output Power 1 x 600W (4Ω) or 1 x 1200W (2Ω)
- CEA 2006 Power (THD + N = 1%) 1 x 300W (20Hz - 240Hz/4Ω)
1 x 600W (50Hz / 2Ω)
54 dBA (ref: 1W into 4Ω)
- Frequency response 10 - 240 Hz
- Distortion
- S/N ratio > 80 dB
- Bass Boost 50Hz, 0 - 12 dB
Remote Controlled
- LPF 40 - 240 Hz (-12 dB/oct)
- MOSFET output section (+) Yes
A MOSFET output section results in enhanced high-frequency range performance and improved linear response to signals. Its high-density circuit layout reduces line impedance in the circuit pattern. This eliminates switching noise and raises sound quality and performance. In addition, amplifier drive stability is maintained even during long, hard-driving listening sessions thanks to excellent thermal stability and circuit protection.
- RCA terminals Yes (input)
- Speaker Terminals Block-type
- Input level control RCA (200mV - 6.5V)
SP (0.8V - 26V)
Switchable, LR independent
- Max. current consumption (A/4Ω) 27 A
- Chassis size (W x H x D) 290 x 56 x 200 mm
- Unit weight 3.2 kg
