Up for sale is a broken Clarion DXZ775USB. Not sure what happened to this one. Face plate suddenly stopped working (Except eject IIRC). Tried everything, resetting the unit, replaced ground, etc to no avail. It was great while it worked.
Wiring harness is in ok condition. Had my brother take it out while I was at work, bad idea. Everything is included, except the original foam from the box. Hair line scratches on the faceplate.
Asking 60 Shipped OBO. If you can fix it you got a killer deal.
Cascade VB2MAXSP. Quality deadener. Half of it is left. 5 Sheets or about 13 square feet. Asking 50 Shipped OBO for this.
Pictures!
Thanks!
- Active capable, Low and Mid are bandpassable and High has a high pass. 20-20khz 1/5 octave I believe
- You can set the crossover points to ANYTHING, in case you wanted to run the tweeter at 20hz and above
- Adjustable gains for all channels (independant)
- L/R (separate) Parametric EQ (3 band), overlap
- T/A for every channel
- USB input and Aux input.
More here: http://www.crutchfield.com/p_020DXZ775/Clarion-DXZ775USB.html?tp=5684
Pictures!
Thanks!
