Sold FS: Cerwin-Vega, US Amps
its_bacon12
I4NI
HED 6.5" coaxials
-6 1/2" 2-way system
-35 Hz - 22 kHz
-(+/- 3 dB): 65 Hz - 20 kHz
-50 watts RMS
-Maximum: 100 watts
-(1w/1m): 90 dB
-4 ohms nominal
-5" (127 mm) mountign diameter
-2 3/16" (56 mm)* mounting depth
35 shipped continental 48
us amps us-x3 3 way active xover, cosmetically flawless.
powers up, works fine. has a plexiglass top so you can see all the internals..
http://www.usamps.com/old_site/products/inv/us-x3.htm
` Three-Way Active Electronic Crossover
` Four Channel Input with Six Channel Output
` Selectable Three-Way or Two-Way Operation
` Nine Volt Outputs with Separate Gain Controls
` 50Hz-500Hz Variable Low-Pass Output
` Variable Mid Range Output with 50Hz-500Hz High-Pass and 500Hz-5KHz Low-Pass
` 500Hz-5KHz Variable High-Pass Output
` Mid Range Phase Inversion Switch
` Delayed Amplifier Turn-On Output
` Fuse Rating: 3 Amps
` Dimensions: (Including Terminals)
32mm / 1.25in High
241mm / 9.5in Wide
165mm / 6.5in Deep
` Weight: 0.91kg / 2.0lb
` MSRP: $379 USD
has built in - up to 9v RMS line driver
110 shipped
ofcourse i will discount if someone decides to buy both...
120 shipped for both
its_bacon12
I4NI
its_bacon12
Norwalk CT
captainham
