Sold FS: carputer, touch screen and CDTES-07 7.0” Mid/Woofer
spicmonster
First off I have for sale a set of cdt es-07 mid bass drivers. These speakers are top of the line cdt. They are in the original packaging opened but never used. Tried to install them but need to modded the door so decided not to use them *All u need is a cross over and tweeter to make them a component set*
which can be had for about 230, the whole set retails for well over 600 and the midbass alone goes for about 420.
Im SELLING these for 300 shipped
http://cdtaudio.com/pdf/ES-07.pdf
Then i for sale a carputer. IT is slighty bigger than a radio and smaller than probably the smallest amp. ITs already built with windows loaded on it. powered up once to make sure it was in working condition. Was going to install it my car ebefore i figured out how to get a double din in my car so theres no real need for it. Paid about 475 for this to be built/all the parts.
Looking for 350 shipped heres all the stats
VIA EPIA M10000 1GHz Nehemiah
--- VIA C3 E-Series 1.0GHz Processor, Nehemiah core
--- 1 DDR266 DIMM socket
--- VIA Unichrome AGP graphics with MPEG-2 Accelerator
--- 1 PCI
--- 2 X UltraDMA 133/100/66 Connector
--- 1 x FDD Connector
--- VIA VT6103 10/100 Base-T Ethernet PHY
--- VIA VT1616 6 channel AC'97 Codec
--- VIA VT1622 TV out
--- VIA VT6307S IEEE 1394 Firewire
SLIM Slot-Load Panasonic CW8123B
--- 24X Speed CD-R Writing
--- 16X Speed CD-RW Writing
--- 24X Speed CD-ROM Reading
--- 8X Speed DVD-ROM Reading
--- Can read DVD-RAM,DVD-R and DVD-RW
--- 12.7mm Height
--- Buffer Under Run Protection
--- Black Bezel
Toshiba 40GB 2.5” HDD
--- 40GB capacity
--- 4200 RPM
--- Fluid Dynamic Bearing (FDB) motor drive
--- 9.5mm High
--- 12ms Average Seek Time
--- ATA-6 Interface
--- 100MB/sec Transfer Rate
--- 8MB Buffer
--- 300,000 MTTF Hours
PQI Power Memory 512mb DDR-266 PC2100
--- Manufacturer: PQI
--- Speed: DDR266(PC2100)
--- Type: 184-Pin DDR SDRAM
--- Error Checking: Non-ECC
--- Registered/Unbuffered: Unbuffered
--- Cas Latency: 2.5
--- Support Voltage: 2.5V
--- Bandwidth: 2.1GB/s
--- Organization: 64M x 64-Bit
Morex 3688 Mini-Itx Case
--- Dimensions: 8.25 x 2.5 x 10.25
--- Color: Black with Blue Face
--- Power Supply: built in 60W
--- Media Drive Type: slim type
--- Hard Drive Size: slim type 2.5” notebook
--- Floppy Drive Bracket: n/a
--- Mainboards: VIA EPIA, EPIA-M, EPIA-ML, EPIA-MII,
--- + AC/DC adaptor with Cord (use this pc in your home)
Then I have a Lilliput 7" VGA Touchscreen, which is great for those carputer applications. Great image on it. Obiviously bought to use with the carputer so im selling it along with the other things. IT goes brand new for 265 plus shipping but I am gonna let this go for 220 shipped.
If your interested in more than one. I can work out a deal.
Specifications / Features:
Screen size: 7 inches diagonal
Physical dimensions (in): 7.33W x 5H x 1.5D
Ratio: 16:9 wide TFT screen
Resolution: 800x480
Dot Resolution: 2400 x 480 (= 1,152,000 dots)
Color configuration: RGB stripe
Video system: PAL/NTSC
2 Video inputs plus 1 Audio input
VGA input (USB interface)
Touchscreen display
IR remote control
Full function OSD control (Multi-language)
Audio output: Speaker built-in
Video input signal: 1.0Vp-p, composite video
High resolution and no radiation
Computer display/S-video/DVD/VCD/Security system/Navigation system compatible
(Rear view camera connectible)
Mount type: Dash board
Power input: DC 12V
Power consumption: 9W
tempting offer....i would love another set of xxx but i woud have no more to install them lol...would like cash...saving up for the z1...pm me maybe we can work something out
spicmonster
spicmonster
New York CITY
spicmonster
