Sold FS: Broken/Untested MA Audio HK-602SX
  • Thread starter EFFENDI
  • Replies 0
  • Views 497
EFFENDI
For sale: MA Audio HK602SX. This amp has an issue with the remote turn-on lead, and the amp will not power up. I'm positive that all it needs is a simple repair. I dont have the time or money to deal with it right now (The Regal project has been a handful lately) so I have listed it for sale on eBay. All the internal components are completely intact, there are some cosmetic issues (shown in pics)
Its on eBay until next Sunday: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5778434817
Note that this is primarily a sub amp, it is designed to perform best with bridged channels. Although it has the flexibility of a 2 channel. Note also that it requires a substantial charging system. Do not try to run this amp on a 60A Honda alternator, and expect full output.
Specs as follows:
400W RMS X 2 @ 4 Ohm
700W RMS X 2 @ 2 Ohm
200W RMS X 2 @ 1 Ohm
1800W RMS X 2 @ 0.5
3600W RMS X 1 @ 1 Ohm
Frequency Response: 20-20kHz
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
0-18 dB Variable Bass Boost
S/N Ratio: >90dB
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
High Quality Power & Protection LED’s
Quiet Fan Cooling System (I can replace the fan with an upgrade for an additional charge)
Thermal / Short / Overload Protection Circuitry
Remote Bass Terminal
EFFENDI
EFFENDI
Los Angeles, CA
EFFENDI
