Sold FS Brand new Kinetik HC800
MatthewR6
I accept paypal. Have refs on here..bdubedube(amp), chinny(xxx), and the latest one is tiz ry(amp). also have refs on ebay.
$90 shipped.
matt
Kinetik HC 800
Compact power that fits anywhere. Use as a reinforcement for amplifiers or as your main battery where weight is a concern, such as racing applications.
* AGM (Absorptive Glass Mat) Technology
* Sealed Non-Spillable, Mounts In Any Position
* Ultra Low ESR (Equivalent Series Resistance)
* More Plates, Stronger Energy Density Providing Higher Voltage Under Load
* Tightly Packed Cells For Superior Heat & Vibration Resistance
Not sure which Power Cell you need? Check out our Power Cell Calculator!
Specifications
Ah Lbs. AMPS CA Dimensions (L x W x H) Suggested Retail
36 26 950 750 7.6" x 5" x 6" (7.1" with post)
(from the kinetik website)
can u confirm those dimentions? I noticed u have the older style case and was curious if the dimentions stayed the same. You battery looks a little bigger than the one the site describes.
theyre right on! its not much bigger than my motor cycle battery.
MatthewR6
MatthewR6
minnesota
MatthewR6
michigan born
    May 14, 2026
michigan born
    May 14, 2026
