Sold FS: Alpine 9887 *200 Shipped*
Lugnutzk
For sale is a 9887 is excellent cosmetic condition. Mechanically when opening the face to insert a CD, it sticks. The video below shows how to open the face plate. Other then that the unit operates flawlessly.
Included:
-ipod adapter
-Remote
-Face plate case
-Manual
-Box
-Trim ring
-Chassis
-Harness
Video
Pic
Features and specs
FEATURES
General
* Remote Control: Remote Control Included
* Mute: Built-in Audio Mute
* Audio Interrupt: Audio Interrupt Input
* Remote Turn-On: Amplifier Remote Turn-On Output
* Power Antenna Lead: Power Antenna Output
* Dimmer: Dimmer Input
* Detachable Face Plate: Detachable Face Plate
* DIN Trim Plate: Detachable Trim Plate
* Clock: Built-In Clock
* Fader & Balance: Fader & Balance Controls
* Bass & Treble: Bass & Treble Controls
* Steering Wheel Control: Steering Wheel Control Ready
* Auxiliary Input: Versatile-Link Ready
* DAC: 24-Bit DAC
* Bluetooth®: Bluetooth Ready
* PreOut: 3 PreOut (4V PreOut)
* Easy Navigating: Quick Search
* Playback: MP3/AAC/WMA Playback
* Illumination Buttons: Blue
* Face Color: Gunmetal Black
* Control Type: Rotary Encoder Knob
* Display: 2 Line Biolite Display
* CD Changer: CD Changer Control
* Power Output: 50W x 4 High Power Amplifier
CD Changer Control
* Repeat: Song/Disc
* Music Control: Play/Pause/Forward/Back
* Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
* Multi-Changer Control: Multi-Changer Control Including MP3 Changer CHA-S624, (with KCA-410C)
* M.I.X.: One/All (Shuffle)
Sound Tuning
* IMPRINT: IMPRINT Sound with MultEQ Acoustic Correction (KTX-100EQ)
* Crossover: Built-In High-Pass/Low-Pass Crossover
* Equalizer: Built-In Graphic/Parametric Equilizer
* Time Correction: Built-In Time Correction
* MediaXpander: Built-In MediaXpander
* Treble Level: Treble Level Adjustment
* Treble Center Frequency: Treble Center Adjustment
* Bass Level: Bass Level Adjustment
* Bass Width: Treble Level Adjustment
* Bass Center Frequency: Bass Center Frequency Adjustment
* Subwoofer Level: Subwoofer Level Adjustment
Disc Player
* M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
* Title Memory: 18 Disc Title Memory Display (Disc Only)
* Playback Control: Play/Pause/Forward/Back
* Music Sensor: Scan/Repeat
* Digital Servo: Digtal Servo
* Zero data Mute: 0 Bit Mute
* DAC: 24-Bit DAC
* Music Playback: MP3/AAC/WMA Playback
* Disc Playback Type: CD/CD-R/CD-RW
* Disc Type: CD Player
Satellite Radio
* Portable Compatibility: SIRIUSPlug N Play Devices (Adapter Required)
* Music Information: Category, Artist, Song
* Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
* Satellite Provider Capability: SIRIUS or XM Adapter Required
* Connection: SIRIUS or XM
* Built-In or Ready: Satellite Radio Ready
Connection for iPod®
* Information Display: Artist, Song, Album
* Percentage Search: Percentage Search
* Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Playlist
* Music Control: Song Up/Down/Repeat
* M.I.X. (Shuffle) Capability: Song, Albums, All
* iPod Compatibility: Full Speed Connection: iPhone, 4th/5th Gen. iPod Video/Photo, iPod mini and iPod nano
* Source Type: Dedicated iPod Source
* Connection: Full Speed Cable (KCE-422i)
* Connection Type: Full Speed Connection for iPod®
Bluetooth®
* Streaming Music Control: Streaming Music Control
* Streaming Music: Streaming Music Playback
* Phone Book: Phone Book Transfer
* Hands Free: Hands Free Calling
* Connection: Alpine KCE-300BT Required. Features may differ between phone model and service providers.
* Built-In or Ready: Bluetooth Ready
HD Radio™
* Multi-Casting: Multi-Cast HD1, HD2, HD3
* Signal Switching: Automatic Digital/Analog
* Status Indicator: HD Radio Satus Indicator
* Connection: Alpine TUA-T500HD Required
* Built-In or Ready: HD Radio Ready
Tuner
* Seek Mode: Local/DX Selection
* Memory: Auto
* Memory Presets: Preset Stations (FM:12/AM:6)
SPECIFICATIONS
General
* Weight: 1.6kg (3lbs 8oz)
* Maximum Mounting Angle: 30° from Horizontal
* Operating Temperature ( °C/ °F): 60 °C (140 °F) to -10 °C (14 °F)
* Pre Output Voltage (Before Clipping): 4V
* Power Requirement: Power Requirement: 14.4 (11-16) V.DC
Dimensions
* Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
* Nose Piece Size (W x H x D) mm: 170mm x 46mm x 24mm
* Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/4''
* Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm
* Din Size: 1
Remote Control
* Weight: 1.5kg (3lbs. 4oz.)
* Dimension (WxHxD) in: 1-21/32'' x 4-25/32'' x 29/32''
* Dimension (WxHxD) mm: 42mm x 121mm x 23mm
* Battery Type: AAA Batteries (2 pcs.)
* Model Number: RUE-4202
* Included/Ready: Included
Sound Tuning
* IMPRINT: Automatic Acoustic Correction & Computer Interface (KTX-100EQ Required)
* Crossover: Flat/6/12/18/24dB oct., 20-200Hz (High-Pass/Low-Pass)
* Time Correction: Adjustable 6 Ch. Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW)
* Equalizer: 5 Band Parametric (20Hz - 20KHz, 1/3 oct. Steps), 7 Band Graphic
* MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off)
* MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off)
* Treble Level Control Range: +/-14dB at 10kHz
* Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
* Bass Level Control Range: +/-14dB at 100Hz
* Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
* Bass Center Frequency: 60/80/100/200Hz (Selectable)
* Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
* Number of Channels: 2-Channel (Stereo)
* AAC Decoding: ACC-LC format ''/m4a'' file
* WMA Decoding: Windows Media™ Audio
* MP3 Decoding: MPEG-1/2 AUDIO Layer-3
Disc Player
* Audio Signal-to-Noise (S/N): 105 dB
* Oversampling: 8x/352.8kHz
* Wow & Flutter (%WRMS): B.M.L.
* DAC Type: 24-Bit DAC
* Total Harmonic Distortion (THD): 0.008% (at 1kHz)
* Dynamic Range (1kHz): 95 dB
* Channel Separation (1kHz): 85dB (at 1kHz)
* Frequency Response: 5-20k ±1 dB
AM Tuner
* Usable Sensitivity (IEC Standard): 22.5/27.0 (µV/dBf)
* Tuning Range: 530-1, 710kHz
FM Tuner
* Capture Ratio: 2.0 dB
* Stereo Separation: 35.0 dB
* Signal-to-Noise (S/N): 65.0 dB
* Alternate Channel Selectivity: 80.0 dB
* 50dB Quieting Sensitivity: 13.5dBf (1.3 µV/75 ohms)
* Mono Usable Sensitivity: 9.3dBf (0.8 µV/75 ohms)
* Tuning Range: 87.7-107.9 MHz
Max Power Output Ratings
* Max Power Output: 50W x 4
CEA-2006 Power Ratings
* CEA-2006 Power Rating: 4 Ω @14.4V ≤1%THD+N, S/N 80dBA (ref.1W into 4 Ω), 18W x 4
Price is firm, no trades excepted. Shipped price is lower 48 only.
How will the T/A work if i ran front outputs to mid amp and high amp, and rear output to front midbass amp?
or should i just run front output to crossover and let it do the rest?
It has a 6 position TA IIRC. So I gather you are going to run highs off the front preouts and mids off the rear preouts? it has a 3-way xover so you can HP the highs, BP the mids, and LP the sub.
BTW it's sold //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Lugnutzk
Lugnutzk
Detroit, MI
Lugnutzk
