I would like to get $180 for this h/u, only $7 more and you can have the aux imput cable tha cooks via Ai net and has 2ch rca plugs for an imput.
It does not come with a cage, i never got one for it since i only bought it last week. It does come with a remote though.
There is no rubber ring around the volume knob either, when i recieved it the rubber ring had expanded causing the volume knob to not pop out, i just removed it so it would work.
It works flawlessly, plays scratched CD's just fine..if you tend to scratch them //content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
This h/u will do active 3 way active crossovers.
Id give it a 9/10 because the rewind/fastforward buttons are faded. You can see them fine at night.The face itself has no scratches on it and it folds out smoothly.
Here's some specs off crutchfield about it:
FantomFace XL motorized stealth faceplate
MaxTune SQ tuner
plays MP3 files on CD-R and CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MOSFET50 internal amp
XM Satellite Radio controls
Bass Engine Pro (5-band parametric EQ, 6-channel time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
4-volt front/rear/subwoofer preamp outputs
clock
wireless remote
20 watts RMS/50 watts peak x 4 channels
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
http://www.crutchfield.com/S-2n844SlCiST/cgi-bin/ProdView.asp?I=500CDA7897
http://vault.alpine-usa.com/products/documents/OM_CDA-7998.PDF
7998 and 7897 are the same except for the display and the 7897 has an internal amp, the 7998 does not.
P.S
This h/u will go active using internal amp...ive tried it and it works great //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
MaxTune SQ tuner
Media Xpander
clock
wireless remote
P.S
