Sold FS: Alpine 7897 ( 7998's little brother)
supa_c
Abministrator
I would like to get $180 for this h/u, only $7 more and you can have the aux imput cable tha cooks via Ai net and has 2ch rca plugs for an imput.
It does not come with a cage, i never got one for it since i only bought it last week. It does come with a remote though.
There is no rubber ring around the volume knob either, when i recieved it the rubber ring had expanded causing the volume knob to not pop out, i just removed it so it would work.
It works flawlessly, plays scratched CD's just fine..if you tend to scratch them //content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
This h/u will do active 3 way active crossovers.
Id give it a 9/10 because the rewind/fastforward buttons are faded. You can see them fine at night.The face itself has no scratches on it and it folds out smoothly.
Here's some specs off crutchfield about it:
FantomFace XL motorized stealth faceplate
MaxTune SQ tuner
plays MP3 files on CD-R and CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MOSFET50 internal amp
XM Satellite Radio controls
Bass Engine Pro (5-band parametric EQ, 6-channel time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
4-volt front/rear/subwoofer preamp outputs
clock
wireless remote
20 watts RMS/50 watts peak x 4 channels
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
http://www.crutchfield.com/S-2n844SlCiST/cgi-bin/ProdView.asp?I=500CDA7897
http://vault.alpine-usa.com/products/documents/OM_CDA-7998.PDF
7998 and 7897 are the same except for the display and the 7897 has an internal amp, the 7998 does not.
P.S
This h/u will go active using internal amp...ive tried it and it works great //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i had both the 7897 and i have the 7998. the 7897 is ****in awesome but hter is no way it's better than my 7998. the 7998 has higher preout voltage on average (test were done ona few and the volatage was lower than the claimed 4v)and the 7998 sounds a tiny bit cleaner, most likely bc of the internal amp. the 7997 i still a ****in awesome hu though and the graphics do look a litl better than the 7998s. greta deal on the last on alpines real hus.
supa_c
Abministrator
supa_c
In a chair
dalucifer
