Sold FS: Alphasonic PMA-640HCA - $225 OBO
sundownz
Pro Seller
Supporting Vendor
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
# 4-Channel High Current Power Amplifier
# RMS Power Rating:
* 160 watts x 4 chan. @ 4 ohms
* 290 watts x 4 chan. @ 2 ohms
* 490 watts x 4 chan. @ 1 ohm
* 500 watts x 2 chan. @ 4 ohms bridged
* 825 watts x 2 chan. @ 2 ohms bridged
* 960 watts x 2 chan. @ 1 ohm bridged
# Hour Meter
# Remote Mount Digital Voltmeter Included
# Bass Remote Included
# Clear Acrylic ANL Fuse Holder and 80 Amp Fuse Included
# Heavy Duty Heat Sink
# Beveled Clear Acrylic Protective Cover
# 1 Pair RCA Outputs
# Tiffany-Style Input and Output RCA Jacks
# High Speed Switching Power Supply
# Double-Sided Glass Epoxy Circuit Board
# Variable Low-Pass Filter: 50 - 250 Hz
# Variable High-Pass Filter: 50 - 250 Hz
# Variable Subsonic Filter: 15 - 60 Hz
# Variable Bass Boost @ 45 Hz: 0 - 18 dB
# Input Sensitivity: 200 mV - 8 V
# Input Impedance: 10,000 ohms
# 4-Way Protection Circuitry: Thermal, Short-Circuit, Overload, and DC Offset
# On-Board Hook Up Terminals
# Frequency Response: 5 Hz - 50 kHz
# Dimensions: 19-3/4" L x 9" W x 2-5/8" H
Free bump to say that, I really dig how sundownz sets up his FS posts!
All the info is in the title, straight to the point info in the body of the post, great stuff for sale...but the info in the title alone is great so you know what your looking at before you even open the thread.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
hrtbrk1
michigan born
    May 14, 2026
michigan born
    May 14, 2026
