Sold FS: Almost brand new Polk SR series 12" woofer and JBL BP1200.1 amp *PICS*
probmxstyle
The Well Dressed OG
Ok so up for sale is my almost brand new Polk SR series 12" Dual 4 ohm sub. Looks and plays brand new, only have had it for about a month and its perfect. I still have the owners manual for it also. The sub plays beautifully and has awesome SQ. Polk put alot of R&D into this sub. Here are the specs:
Size 12 -inch
Impedance 4 ohms
Cone Material ABS plastic
Surround Material Butyl rubber
Sealed Box Volume (cubic feet) 0.88
Ported Box Volume (cubic feet) N/A
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil Yes
Sensitivity 85dB
Frequency Response 20 - 0.2k Hz
RMS Power Range (Watts) 100-700
Peak Power Handling (Watts) 1400
Top Mount Depth (inches) 7 13/16
Bottom Mount Depth (inches) 8 3/16
Cutout Diameter or Length (inches) 10 15/16
Vas (liters) 53
Fs (Hz) 30
Qts 0.55
Xmax (millimeters) 16.25
Parts Warranty 3 Years
Labor Warranty 3 Years
I am looking to get 300 shipped for it, which is a steal.
so how did you like the Polk SR comps with the SR subs? How'd it sound? I may be picking up the same setup.
They sound awesome together. Blend with eachother seamlessly. The SR comps dont play extremely loud, but thats not what there designed for. They sound as if someone is playing right infront of you. Imaging is excellent even if you dont have optimal placement. Also, the sub is the most musical sub I have owned.
bump for solid, well built amps. I pulled one out of a customer's trunk and it was DRENCHED - dried it out for a day, and it powered up and still pounded a pair of subs like it was new. couldnt believe it, never seen an amp do this...
probmxstyle
The Well Dressed OG
probmxstyle
MD
probmxstyle
