Sold FS: Adire Audio Brahma MKII 15" D2, JL 13w7
supermaxx123
I've owned this subwoofer for about 2 years. It hasn't seen much play time. When i bought it, guy said he had just got it reconed. there is only one bad thing about it, bottom of the magnet has a little of the chrome flaked off, other than that the sub is m int. I had it in a 3.4cu/ft tuned to 33hz and it sounded quite loud off about 500rms in my room. 200+ shipping.
The Bad //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
my friend said he wants $350+ shipping for the 13w7, has scratches on the surround, no tears.
ill trade you a custom built enclosure for it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif carpet the whole works! anything you want you name it bro!
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
Re2 0.75 Ohms parallel
Le3 0.45 mH parallel
BL 15.9
Sd 749 cm2
Xmax 28mm one way linear
Pmax4 1600W RMS, 4800W peak
NOTE: Power rating is thermal only! It is NOT a power requirement; typically you get full output with significantly less power than the rating.
SPL5 87.6 dB @ 1W, 1m
Diameter 15.5"
Cutout 14"
Depth 8.25"
Volume 0.18 cubic feet
Weight 41 pounds
Application
Sealed Car 1.25 to 2.5 cubic feet
Vented Car 2 to 3.5 cubic feet tuned to 28 Hz
Sealed Home 1.5 to 3 cubic feet
Vented Home 5 cubic feet tuned to 20 Hz
Infinite Baffle CAR: Yes HOME: Yes
How about 2 12" type R's and 50 for the brahma? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tempting, but i wouldnt be able to use those. Looking for a plate amp and a 10" 300-800rms fs 30-45hz.
Think about this........ You take the 50$ //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif and get that jig! Then you have the r's for your room! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif perfect!
what about shipping? there go the $50. My room is good with the e8 i've got, I have 2 IDQ 12's and i doubt the typr-rs will sound better:( Im sure they are loud though!
supermaxx123
supermaxx123
I.E.
supermaxx123
