FS: 55ah DEKA batts
michaellane
55ah batts
In the box
$90 shipped each
No sir. No matter how many are sold it cost the same to ship. In person I give a good deal. And I gqve a deal on 10 shipped before but thats it.
---------- Post added at 04:16 PM ---------- Previous post was at 04:16 PM ----------
Youre correct
Would this battery be enough to eliminate my dimming lights till I can afford a new alt? Gonna be running 1krms
Sent from my Z812 using Tapatalk
Id need more info then that.
what gauge wire are you using
what amps at what ohm
what car
Big 3 done
Id need more info then that.what gauge wire are you using
what car
Big 3 done
For now I'd be using 4guage till I can afford 20ft of 0 lol be using the Rockville RXD-M3 @1ohm and yes big 3 is done in 1990 bronco 2 (same as ranger)
you'll only fix dimming lights if you never drop below 14v or so, even then you'll dim on heavy bass lines. alternators will help you there, batteries will help you from dropping below 12-13v and will provide more capacitance for your amps (i.e. it will get louder due to the extra available current, ive experienced it real world).
The battery will help for sure. If youre dimming on only 1000 watts id guess your baytwry that you have now is really really old. Id also make sure all conncetions are tight
Not running 1k yet I'm running a pyramid amp only rated at 150watts rms but I feel it's super power hungry I have very little dimming probably due to the fact that the previous owner put a Honda civic battery in it supposed to be group 65 its got like a group 50 now
what amp? Got a pic of the amp?
Pyramid pb717x
here's a pic of the front cover I took it off cause an old RCA broke off inside the plug and lost the screws
Theres absolutely no reason to dim using that. Check all your wires and connections. Id bet the battery is on its way out.
Found out the solenoid was old but yeah I know the battery needs to be replaced. Would this one work as a starting battery would it fit in a group 65 tray?
No idea if it would fit or not youd have to check honestly
michaellane
michaellane
tx
big scott
