FS 3 DC audio lvl3 12's dual 1 ohm.
JRCF71
View attachment 26549745Item(s) for Sale:
Used but in excellent condition visually, and fully functional mechanically. They are 8 months old, purchased in 12/11/13. Used in my daily driver car.View attachment 26549740
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• Dual 8” OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire sewn to spider
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 4 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
• Rubber magnet cover
10" 12" 15" 18" Mounting Depth 6.25" 6.75" 8" 9.5" Mounting Hole Diameter 9.35" 11" 14" 16.75" Outside Driver Diameter 11" 12.5" 15.7" 18.5" Motor Width 7" 7" 7" 7" Weight 20lbs 20.5lbs 21.5lbs 22lbs VC Diameter 3" 3" 3" 3" Displacement .15³ ft .16³ ft .18³ ft .22³ ft Magnet Weight 18lbs 18lbs 18lbs 18lbs Power Handling RMS/Peak 900/1800 900/1800 900/1800 900/1800 Impedance (Ohm) D1/D2/D4 D1/D2/D4 D1/D2/D4 D1/D2/D4 Sd 324cm² 481cm² 823cm² 1217cm² Vas 13.16 liters 28.99 liters 84.88 liters 185.6 liters Cms 0.09 mm/N 0.09 mm/N 0.09 mm/N 0.09 mm/N Mms 190 g 225 g 295 g 305 g Fs 38.5 35.4 30.9 30.4 BL 17.2 N/A 17.2 N/A 17.2 N/A 17.2 N/A Re 3.6 Ohm 3.6 Ohm 3.6 Ohm 3.6 Ohm Le 3.5 mH 3.5 mH 3.5 mH 3.5 mH Qms 7.66 8.33 8.18 8.32 Qes 0.567 0.617 0.706 0.718 Qts 0.528 0.574 0.65 0.661 Xmax 23 mm 23 mm 23 mm 23 mm Ref SPL @ 1 watt 83.1 dB (86.6@2.83V) 85 dB (88.5@2.83V) 87.3 dB (90.8@2.83V) 90.4 dB (93.9@2.83V) Suggested Sealed .65³ ft 1³ ft 2³ ft 4³ ft Suggested Ported 1.0³ ft 1.25³ ft 3.0³ ft 5.5³ ft
170 each shipped. Will ship in original boxes.
JRCF71
JRCF71
Victorville, CA
JRCF71
