I am selling a pair of used JL Audio 8IB4 8" woofers. They are in perfect working condition and very good physical condition (no punctures, voice coil scratching, tinsel burn, or rust). They had some pigtails that have been clipped, the frame has some installation wear, and the gaskets are a little worn. You can get the grills from the JL Audio site for $7.95 each. They will be DOUBLE BOXED.
Hands down the best midbass driver I've used. I've used/tested 8 different 8" woofers (Seas, Peerless, Dayton, Audax, Dynaudio, JL, JBL) .
JL Audio 8IB4 Specs:
FS: 37.5 Hz
QTS: 0.684
QES: 0.744
QMS: 8.484
VAS: 50.9 L
Xmax: 8.6 mm
SPL: 87.4 dB
Sd: 0.0198 m2
Re: 6.10 ohm
Z: 8 ohm
Pw: 75 Watts
Mount Depth: 3.875 in
Frame Dia: 8.25 in
Mount Dia: 7 in
Magnet Dia: 4 in
SOLD
FS: 37.5 Hz
QTS: 0.684
QES: 0.744
QMS: 8.484
VAS: 50.9 L
Xmax: 8.6 mm
SPL: 87.4 dB
Sd: 0.0198 m2
Re: 6.10 ohm
Z: 8 ohm
Pw: 75 Watts
Frame Dia: 8.25 in
Mount Dia: 7 in
Magnet Dia: 4 in
SOLD
