Sold FS: 20.1 and Diamond Audio D5 300.2
Rc 415
20.1 has been used, great amp, but I need more power now!
Dont need to sell it so 500 + ship
300.2 has never seen power, 1 of a kind black.
150+ ship
D5 300.2
FEATURES
Technical
• Fully Regulated Power Supply
• Up To 5V RMS Input Signal Voltage Capability
• High pass x-over 12 dB/oct. 1.5 kHz-15 kHz Subsonic 15-1.5 kHz
• Adjustable Q with a 10 dB boost
• Low pass x-over 12 dB/oct. stereo 50 Hz-5 kHz, mono 24 dB/oct. 50 Hz-5
kHz
• RCA Outputs
• 2 oz. Silver Plated Copper Circuit Board
• Massive Proprietary Heatsink
Convenience/Appearance
• Fully Variable Electronic Crossovers
• Nickel Plated Solid Brass, Circuit Board Mounted, 4 Gauge Direct
Power/Ground Connector Blocks
• Nickel Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or
Banana Plug Direct Speaker Connectors
• Fly Cut Billet Aluminum End Plates
• Fully Adjustable Mounting Feet
SPECIFICATIONS
Frequency Response: 10 – 50,000 Hz
Signal-to-Noise Ratio: 100dB
THD: 0.03%
Channel Separation: 80dB (min.)
Input Sensitivity: .2 to 5V RMS
Input Impedance: >20k Ohms
Power Supply Operating Range: 11 to 14.5V DC
D5 300.2
75W x 2 @ 4 Ohm Stereo
150W x 2 @ 2 Ohm Stereo
300W Bridged @ 4 Ohms
D5 300.2
Length: 12 1/2"
Width: 12"
Height: 2 3/4"
Features:
Power Ratings: 1800 watts x 1 at 1 ohm
900 watts x 1 at 2 ohms
450 watts x 1 at 4 ohms
Strapable Pair: 3600 watts x 1 at 2 ohms
Protection Circuit 3 Way (Overheat, Overload, Short Circuit)
Frequency response 10Hz~350Hz
Signal/Noise Ratio 105dB
T.H.D @ 4 Ohm
Efficiency @ 4 Ohm 87%
Low Pass Filter 45Hz~300Hz
Subsonic Filter 20Hz~50Hz
Bass Boost Slope 0~18dB
Size: 10.25" Wide x 2.25" Height x 21.75" Long
four50 at four ohms.....900 at 2 ohms 1800 at 1 ohm some people say alot at .5 i think i could be wrong on a strong electical
well it depends on what you consider alot LOL. I'd probably say around 2500-3000 depending on the electrical @ .5 Im hoping to get around 3000 on mine with .35 just need to finish my box to pop my sub in.
Rc 415
Rc 415
San Francisco
BAsK510
