Sold Fs / (2) Zed Audio Miniliths....
talibmohamid
The Jay-Z of Car Audio
I have had these amp since 3/28/2007 , had them installed 2 ways.......ran dual 12" JL Audio 12W6v2's with one amp on each sub, sounded god-LIKE, after doing that I strapped them together and ran a single KICKER 15" dual 4 ohm CVX.......powered the sub very well........at less than half the gain......"ABOUT TO GET A NEW CAR so I'm done with the car audio for now.......tryin to get this down payment together"
Have owners manuals and everything that came with these amps....even the boxes...and can show proof of purchase...and dates.........
selling for
$200.00 a piece plus shipping........$25.00 / amps are heavy,,,,,,,//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
"DON'T MISS OUT ON THESE.....they are truely monsters....some of the best amps out here......" CHECK PICS
LET ME KNOW GUYS.....these gotta go......
Minilith Specifications
Output Voltage (volts into 1 ohm) 24.5
Output Voltage (volts into 2 ohm) 28.3
Output Voltage (volts into 4 ohms) 28.3
Output Current (amps into 1 ohm) 24.5
Output Current (amps into 2 ohm) 14.15
Output Current (amps into 4 ohms) 7.075
Continuous Output Power into 1 ohm 600wx1
Continuous Output Power into 2 ohm 400wx1
Continuous Output Power into 4 ohm 200wx1
Typical Continuous Output power into1 ohm 650wx1
Typical Continuous Output Power into 2 ohm 480wx1
Typical Continuous Output Power into 4 ohm 260wx1
Continuous Output Power 2 channels bridged into 2 ohm 1,200w x 1 *
Continuous Output Power 2 channels bridged into 4 ohm 800w x 1 *
Continuous Output Power 2 channels bridged into 8 ohm 400w x 1 *
* With TWO Miniliths bridged
Minimum Speaker Impedance 1 ohm
Minimum Speaker Impedance in Bridge Mode 2 ohm
Frequency Response at 1 watt into 4 ohms/channel 11-150Hz -3dB
Frequency Response at rated power into 4 ohms/channel 11-150Hz-3dB
Input Voltage range for rated power into 4 ohms 0.22-7.4 volt
Input Impedance (10K ohm on “mono-bridge” input) 39K ohm
Noise below rated output (30KHz limited) -89dB
Channel separation at 2KHz Infinite
Damping Factor at 20Hz with 4 ohms >100
Total Harmonic Distortion with 4 ohm 20Hz-150Hz
From 1 watt to 2dB below rated power
** Frequency range 20-150Hz only
Low Pass Crossover (24dB/octave) 40-235Hz
High Pass Crossover (24dB/octave) 11-48Hz
Equalization Parametric 26-160Hz
Remote Level Port with control Yes
Line Output Yes
Protection - Short Circuit, DC, Thermal Yes
Power Source ----10-14.5v DC Negative Ground ----
Current Consumption with Sinewave at 4 ohms 20A
Current Consumption with Music at 4 ohms 6A
Idling Current
Size W x H (302.22mmx74mm/11.9”x2.91”) x L 314.4mm/12.4”
Shipping Weight (Kg/Lbs) 7.3/16
Fuse rating *** 35A
*** May have to be increased by 40% when driving high power into 1ohm loads
Dont hesitate from this guy, just received my new HU from him, he kept me updated every step of the way and even provided his personal phone. Thats a good price for some high quality amplifiers....
I wish I had the money for one. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif It would power my sub perfectly... Bump for some very nice amps, and a seemingly decent guy! Great prices.
talibmohamid
talibmohamid
Jonesboro, CA
talibmohamid
