Sold FS 2 sets 6.5 comps and 4chan amp
csu87
Ive got 2 sets of BNIB Soundstream PCC6.N component sets. I also have a BNIB Cadence TXA3004. And lastly i have a Pioneer GM-3300T
SOUNDSTREAM PCC.6N 6
Detailed Product Description
*Brushed Stainless Steel Finish Stamped Steel Baskets
*Woven Glass Fiber/Spruce Pulp Laminate Cones
*Inverted Polypropylene Dust Caps
*NBR Rubber Surrounds
*Black Progressive Conex Spiders
*1" Copper Voice Coil on Aluminum Former with Reinforced Neck Joint
*Nickel Plated Binding Posts
*Rubber Motor Cover with Logos
*Vented Pole Pieces
*4 Ohm Impedance
*1" Teflon/Silk Dome with Resin Coating Tweeters
*Neodymium Tweeters Magnets
*Ferrofluid Cooling
*Multi-Function Mounting Set
*Passive Crossover with 12dB Low-Pass and Presence Switch for Midbass, 18dB
*High-Pass with 3-Way Sensitivity Switch for Tweeter, Tweeter Protection Circuit
*Grills and Mounting Hardware Included
RMS PWR (W) : 125
MAGNET WEIGHT (Oz.) : 13
CROSSOVER FREQUENCIES
HIGH-PASS (Hz) : 3.3K
LOW-PASS (Hz) : 3K
SENSITIVITY : 91dB
CROSSOVER SLOPE : 18dB
FREQUENCY RESPONSE (Hz) : 50-20K
VOICE COIL SIZE (INCHES): 1
WOOFER MOUNTING DEPTH : 2.6"
Cadence TXA-3004
# 4 Ohm RMS Power: 4 x 75 Watts @ 13.8 Volts
# 2 Ohm RMS Power: 4 x 150 Watts @ 13.8 Volts
# 4 Ohm Bridged RMS Power: 2 x 300 Watts @ 13.8 Volts
# Frequency Response: 20Hz - 30kHz
# Damping Factor: >200 @ 100Hz
# S/N Ratio: >100 db
# Channel Seperation: >65dB
# Minimum THD:
# Dimensions: 17" x 9.2" x 2.12"
Pioneer GM-3300T
* 60 Watts x 2, at 4 ohms
* 150 Watts x 1, at 4 ohms BRIDGE
* 80 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
PRICE
$80 shipped each component set(pending)
$100 shipped on Cadence amp
$40 shipped on Pioneer(sold)
All prices are OBO
csu87
csu87
C Springs, CO
csu87
