Sold FS~2 RE Audio RE8's
brmcm15
Oh lawdy!
Older version not new.
just bought one and got one in a trade and thought i was going to use them, but im not lol
looking for $85 shipped O.b.O
the only problem with the one is that there is a dent on the dustcap, which is no big deal.
Specs? Dvc?
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total Speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency - SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm per coil
Mounting Depth - 4”
Mounting Hole Diameter - 7.125”
Overall Diameter- 8.25”
Bolt Hole Circle - 7.75”
Motor Width - 4.875”
Motor Depth - 1.5”
Basket Depth - 2.5”
Displacement - .07 cu. ft.
Weight - 6 lbs.
Mica Filled Poly Cone
Santoprene Rubber Surround
Pressed Steel Basket
High Temp 8-layer Copper Voice Coil
FEA Optimized Motor Structure
Single Magnet
Linear Conex Spider
Foam Gasket
75 shipped is a nice price. i just got 2 of these (new version) for 78 shipped for a pair. looked along time for that price too. id jump on these if i was getting the old ones =P free bump
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
Lizardkinged
