Sold FS 2 Pioneer Premires Ts-w3004spl
MRCADDY
I HAVE 2 PIONEER PREMIRES TS-W3004SPL FOR SALE PRICE IS 180.00 FOR BOTH PLUS SHIPPING I TAKE PAYPAL PAYMENTS HERE IS THE EMAIL a-paul2@hotmail.com I also have them up on ebay user name is allx60 look it up and check my feedback!!!!!!!!!
HERE ARE THE SPECS
12"
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil
Voice Coil Wire Ceramic-Coated
Voice Coil Bobbin Titanium
Damper (Spider) Super Aramid Fiber
Damper Ring Yes
Top Plate Thick 7/8" (23mm)
Projected Pole Yoke with Vented Pole
Aluminum Heatsink Cooling System
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Spring-Compression Binding Posts
Specifications
Watts MAX. Music Power 3000 Watts
Watts Nominal Power Handling 1000 Watts
Frequency Response 18Hz ~ 700Hz
Sensitivity 89dB
Ohm Rating DVC (Dual 4 Ohm Coils)
Recommended Enclosure 0.85 ~ 1.75 Cubic Feet
Dimensions 13" x 8.1" (329 x 205mm)
Mounting Depth 7.3" (185mm)
THAT IS THE TECHNO STUFF HERE IS WHAT I KNOW THEY SOUND GOOD I HAVE HAD THESE FOR ABOUT TWO MONTHS THEY ARE SLIGHTY USED IF MORE PICS ARE NEEDED I WILL POST MORE
yhea that one of the I used rtv sealent on it but when I got it and hooked it up the performance wasnt affected at all but used the sealent as a precaution I have pics if anyone like to see them
MRCADDY
MRCADDY
chicago,IL
MRCADDY
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
