2 JL AUDIO 10W3V3-4 10" SUBS + ATREND SUB BOX ENCLOSURE
These were purchased Brand New a month ago from Audiosavings. Gently used less than 3 weeks, still in excellent like new condition!!! Have all original paperwork & warranty information.
Hit, loud, clean, and perfect. Will take 500 watts RMS each.
*(From Audiosavings advertisement I bought from)*
Description for JL Audio sub
(You get 2 of these)
The JL Audio W3 series is on of the best sounding series of subs ever built! The 10W3V3-4 10" 500 watt RMS 4 Ohm subwoofer screams and roars with efficient and clear power, and this sub will last you a life-time, because this series of subwoofers is made with only the best components and materials. It honestly sounds more like 800 RMS.
Even though these subs are super powerful, you do not need a big bulky enclosure. These sound great in small enclosures.
Every watt is tested to make sure it performs to specifications or better!
If you want the legendary sound quality that only JL Audio can bring, than this is the sub for you! If you want to take these subs and win competitions, you will have no problem. They sound better than anything on the market, and they go really loud!
Features:
* JL Audio 10W3V3-4 10" 4 Ohm W3 Subwoofer
* 500 watts RMS (JL Watts)
* 1000 watts peak
* Impedance: Single 4 ohms
* Mineral-filled polypropylene upper cone
* Nitrile Butadiene Rubber surrounds
* DMA-optimized, long linear excursion capability
* Clean sound Quality with no distortion
* Big power even with small sealed or ported enclosures
* Dynamic Motor Analysis
* Efficiency: 84.87 dB SPL
* Free Air Resonance (Fs): 31.49 Hz
* Electrical "Q" (Qes): 0.523
* Mechanical "Q" (Qms): 7.017
* Total Speaker "Q" (Qts): 0.485
* Equivalent Compliance (Vas): 1.138 cu. ft (not recommended box size)
* Xmax Linear Excursion: 0.550 in. / 14.0 mm
* Driver Displacement: 0.049 cu. ft.
* Net weight: 12.25 lbs.
Description for Atrend Enclosure:
The Atrend E10DSV is a dual 10" vented/ported subwoofer box. The thickness of these boxes are unmatched! The front panel of the box where the sub gets mounted is made of extremely thick 1" inch MDF wood. The rest of the box is built with 3/4" high-grade MDF construction. While other manufacturers use 3/4" or less MDF in the front panel, Atrend chooses to use a thicker 1" MDF because the front panel receives the most pressure causing the wood to flex more than the rest of the box. With the thick 1" MDF you will have no warping or breaking of the wood over time, and less distortion from your subs, and significantly improved sound quality. These use top quality glue with multiple coatings to ensure long life.
Features:
* Dual 10" ported/vented subwoofer enclosure
* Dimensions in inches: 30" Width x 12" Height x 16" Top depth x 16" Bottom Depth
* Volume per sub: 1.3 cubic feet
* Machine precision cut mounting holes
* 3/4" heavy Dusty Construction
* Multi layers of high-grade glue ensure long life and no air leaking out
* High quality spring loaded terminals
* Mounting Depth: up to 16" (enough depth for any sub on the market)
* Dado end panels
* Designed, tested, and engineered to work with most of today’s popular woofers. These enclosures are built with the quality additives needed to maximize the performance of any sound system.
A steal at $200 (you pay shipping or local pickup)
Paypal verified, references from ebay and craigslist available. 100% Feedback Rating
http://www.caraudio.com/forums/newthread.php?do=postthread&f=6
Features:
* 1000 watts peak
Features:
* Dado end panels
