Sold FS: (2) 240 watt Dayton Plate amps
Fast1one
One of them is used, while the other is nearly new. The used one has short wires from the previous owner. But nothing to cry about. Both received very light use in my home rig. I have (1) data sheet that will be provided for the new one. No original boxes, sorry.
New: 95 shipped
Used: 85 shipped
Both: 150 shipped
Prices are pretty firm, but don't be afraid to send me offers.
A new animal is prowling the subwoofer amp jungle! Behind the less than 10" x 10" faceplate lurks a tiger of a 240 watt amp, ready to unleash its power on your subwoofer driver. Includes all the features that you have requested, like a choice of RCA line level or banana jack speaker level inputs and outputs, automatic turn-on that is triggered by an input signal, and a phase reverse switch to match the subwoofer to your room and your other speakers. A single amp can accept a stereo input signal and combine it into mono, which is optimum for sub bass reproduction. The internal low pass crossover is fully adjustable between 40 and 180 Hz, and of course the amp has built-in protection against internal and external faults. Unleash the beast!
Dimensions: 9-13/16" W x 9-13/16" H x 5" D. Cutout dimensions: 8-1/2" W x 8-1/2" H.
High power/low distortion
Adjustable low pass crossover
High and low level inputs/outputs
Auto On/Off
Phase reversal switch
Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms
S/N ratio: 90 dB (A-weighted)
i could maybe use these to run my speakers...what do you think? hooking each one upto a 270 watt speaker?
Unfortunately these have a non-defeatable low pass, so they wont work for speakers. I was personally using them to run a pair of woofers to 150hz... stereo bass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
trades? only need one
No thanks, I have everything I need.
Folks, the price is very FIRM for the pair, since they are priced to sell as a pair. I am taking a loss as it is.
I decided that If I am going to sell individually, then I would like to have buyers for both for now. I don't want to sell one then have one taking up space in my house. Thanks!
would i be able to hook both of these up into my 12in kicker sub? if so i might be interested
Depends on the sub...
If its dual voice coil and it is Dual 4 or Dual 8 then yes it would work. You would just have to set your gains with a DMM to ensure that the output of both amplifiers is identical. Or you can get a second sub and use one sub per amp. These are only stable down to 4 ohms. Pretty much all plate amps are rated at 4 and 8 ohms.
Dont need subs... matter of fact I really dont need anything, only selling //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fast1one
Fast1one
California
Fast1one
