Sold FS: 10" TC-3000, TC Sounds IS-101, (2)Passive Radiators
XaznKewLguyX
bloop
So.. im lookin to try some new subs.. im leaning towards a SI Mag or SI Bm so these have got to go. There is absolutely nothing wrong with these and they are both amazing drivers.
The TC-3000 has less than 10 hours of use on it. Its been getting about 1100-1200w RMS from my MD2 @ 1.5ohms. Only time i pushed it real hard was when i used it for bassrace and even then i only pushed it hard for less than a minute. It is in very good condition. It is truly a great sub! I'm sure it could get much much louder in a better box. I had it in a 1cuft with 2 PR's. I'm sure it would much better and louder in a regular slot ported box.
Next up I have a TC Sounds IS-101. This sub sounded REALLY clean with a good amount of output off of 600w from my MD2, it could probably get much louder in a better box and more power, I had it in a .6cuft sealed. The bad thing about this sub is that it is SVC4ohm. TC Sounds recommends you use PR's with this sub but I never got the chance to try it but I'm sure it would be an awesome set up. This sub only has about an hour of use on it. It is still stiff as f*ck and probably still needs a break in. Kyle @ TC sounds says the T/S parameters are identical to the OEM's so I it if you need them.
SOLD!!
Last I have 2 PR's with the honeycomb cone. Used them with the TC-3000 so they have less then 10 hours of use also. Never understood how to use these but they do help a lot with low end extention. i already cut the bolt thing so it isn't so long. All the weights and nuts will be included. I can fit 8 weights + the nut comfortably on each PR which is 100g per weight and 170g for the nut.
Prices:
TC-3k - $280 shipped
IS-101 - SOLD!!
PR's - $70 shipped each.
And I do have the original boxes and packaging for all of these
Trades: Mainly lookin for a sundown amps, SI mags or SI bms 10's and 12's only. Nothing bigger. I'm probably open to other offers just post em up. but im pretty firm on Sundownz for amps. Or maybe a 5-ch memphis .
EDIT: All of these are 10"!
I can vouche for this guy and his equipment //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I always baby my equipment //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I don't want to sound like a hater...
do you know if the amount you cut off is enough to affect tuning? if you don't know, I strongly recommend and sure hope you still have the cut off pieces, that you contact Kyle, and if you can on your own, get the pieces weighted to see if the weight you cut off is enough to where you need to counter balance it with more weights... I honestly don't know how much is significant for PR's but I do know I probably wouldn't take the piece you cut off and add it to a sub cone and expect it to be fine... so though it's passive you may not want to remove that much weight, IF you don't know the results, I'm not saying you don't, but humbly inquiring and if you don't making a suggestion. by no means am I telling you what to do...
I understand where your coming from but Kyle did say it was alright to cut it off on a different thread i forgot if it was this forum or the tc forum.. It was a very light piece of plastic and a single weight (100g) would be more then enough to make up for it.
the less weight on the PR = higher tuning so you could just add more weights to lower it. I can guarentee that kyle said it was alright to cut it off because someone else was having clearing issues for a box that is only .6cuft and a sub with a 9in mounting depth and the PR with a mounting depth of 6in before being cut.
bump, im open to offers just please dont lowball. Also would be willing to trade for a ported 10" box. that way i could keep one of these subs perhaps. Also got some kicker hyperflex 0awg enough for a big 3 and us amps merlins md2 and md41. but those are just feelers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
XaznKewLguyX
bloop
XaznKewLguyX
SoCal
XaznKewLguyX
