"The SSD Series of subwoofers is our all around daily sub. Double stack magnets with a heavily bumped T-yoke allow clearance for high excursion. Along with pair of heavy weaved progressive spiders, a multiplayer foam surround attached to a fiber impregnated kraft pulp cone helps keep things under control in high power applications. A 3” 4 layer aluminum voice coil yields 21mm of Xmax while keeping moving mass low. Light weight and versatile, the SSD works in a variety of applications from incredibly detailed sound quality systems, to ground pounding multi sub monsters. The SSD is versatility redefined"
DUAL 2
Fs: 26.3 Hz
Re: 1.5 Ohms/coil
Qms: 4.71
Qes: .49
Qts: .44
Mms: 201g
Cms:0.18mm/N
Sd: 480cm^2
Vas: 58.7 l
Spl: 85.3dB 1W/1m
Bl: 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .8-1.6 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
