FS: 1/8" Mass Loaded Vinyl Acoustic Barrier
bubbagumper6
Bought a 10' x 4' piece of MLV off Amazon for $109. This is the same stuff Don sells on Sound Deadener Showdown (I would have bought from him if he would return my emails but that's neither here nor there). I was planning on doing my doors and floor but after finishing my doors just didn't have the motivation to do the rest so I only used about 3'. What I have left is about 7' x 4'.
I'm willing to cut smaller pieces but would prefer to sell it whole. Only asking $50 + shipping. Shipping will probably be expensive because it's very heavy and a 4' long roll.
Also have some other sound deadening materials (closed cell foam and acoustic filler).
If you only need a smaller piece just shoot me a pm and we can talk.
Can be picked up in the Detroit area.
i may be interested in 4'x4' piece. u could cut it into 1'x2' strips and send it in a flatrate box. ill be using multiple layers above my gas tank to hopefully stop my HDD from killing fuel pumps.
Shoot me a pm if you're serious and I'll get back with you in the morning, going out for the night.
im intrested in this - but how would you apply it to the door skin ? use contact cement or super77 3m spray ? or other ?
my suburban doors have the smallest openings to work thru so some pieces cut to fit in a flat rate box would probably be more ideal for me to try and work with anyways...
i have 6 smaller size doors to apply some kind of deadner to the door skin ( was going to use a peal and stick type deadner but... ive had bad luck with those and the hot south FL sun melting it all off... dont want that happening inside my doors and messing with my window motor junk
Gotta use 3 or 4 1" screws with large washers across the top of it. Use the ccf to seal the edges of the mlv. Stuff is heavy man. Buut, my doors (especially midbass) sound so good now.
bubbagumper6
bubbagumper6
The D
bubbagumper6
