Frustrated!!!!
Id still try popping them with a battery. I remembered I was 100% sure one time with wiring 2 subs parallel- parallel. It showed a 1ohm load but ended up being wired in a dead short. But if your a 100% then they should be fine in that aspect, then its probably the box!
Do you have them wired together and bridged on the amp? or are they wired in stereo on the amp?
i am uploading some video right now.
The first one is volume 22 of 40 so you can see that its maxxing out as far as excursion goes. it pops really bad so i kill it pretty quick.
The second one is me playing late night tip and i am trying to keep the volume just under the point where they start to pop. I adjust it back and forth a few times but i still get a little pop.
Its wired wrong or you amp is messed up. If other subs work fine when you hook them up then its wired wrong. Its that simple. The enclouse should not be making the sub react in that manner.
Check and make sure you dont have a coiled wired backwards.
This is the only thing that seems logical to me. Did you try popping with a battery?
f150_on_32s
f150_on_32s
Thibodaux, La
ls1pimp
