Front stage with only co-axials?
aggybong
Is it worth going for a front sound stage with only co-axials?
I don't really want to get components for permanent modification reasons, but I am looking for better sound quality. My current setup is decent, but I think the Kappa highs are too harsh, and there isn't enough midbass.
My amp can do 50x4 or 100x2 bridged, so I was wondering if I should bother getting a set of high quality co-axials and just running fronts along with the sub, or if I would notice the lack of rears since the tweeters would be near my knees.
Current set-up:
Alpine 9830 Deck
Alpine Kappa 62.5i's
Pioneer TS-A6960R
10" Alpine Type-R
All powered by a SoundStream 800.5 Amp
well if ur goin wif a frontstage of co-axials and ur not goin wif components then y not, if u get a high qual set should be fine
look at it this way a shitty pair of comps is not goin 2 compare wif a good set of co-ax so id say it would b fine
I'm running just coaxials for my fronts...Boston Acoustics FX6's, with 100 watts per channel going to them. Gets loud, sounds good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
a good set of coaxs is basicaly a fixed component set---lots of coaxs come with crossovers, the main difference is that you don't have a seperate tweeter to put where you want it.
I don't know what your "permanent modification reasons" are.....but you can install components without having to permanent modify something.
Anyways, it depends on your definition of "good quality". Bostons are good quality co-axials. Focal has some high quality co-axials. The AURA MR62's that desertheat is using are good but hard to find.
aggybong
aggybong
Milwaukee
desertheat
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
