fried amp.....HELP!
BLD 25
Hey, i need some help. A few weeks ago, i hooked up my amp, and it sparked and a little smoke came out. That worried me, but it still seemed to work. Today, i got a new amp(new to me), an mtx 500d, and hooked it up with no issues. I went back into the car, put the test tone cd in, turned the volume up to 35, and by the time i got back to the trunk the amp was smoking and then it died. I have set up dozens of systems, and never had that happen. Then i put the multimeter on the connections and it started smoking. The thing that ticks me off big is that the fuses on the amp didn't blow, and neither did the inline fuse in the wire.
What happened!!!!!!!!
Possibly a short in your power lead? How big a fuse do you have in it? Just to see, try hooking the multimeter up and seeing if there is any current in the ground lead?
i checked my wiring, and then ran two different smaller amps with no problems whatsoever. Could it be the larger current draw of the 1000w amps caused problems with the not so great ground?
BLD 25
BLD 25
Carbondale, IL
djman37
vegang
vegang
