FOUR 12" T1 D4's
Ranalli
Four 12" D4 Rockford T1's
They are in a box built to Rockford specs.
Was built for S/10 Blazer
All from Big Apple
Nominal Impedance = D4 ohm
Power Handling = 600 watts rms / 1200 watts max
Voice Coil = 3" anodized aluminum
Magnet Weight = 124 oz. Double Stacked
Speaker Connector = Duel 8 AWG Slot Load
Fs (Hz) = 33
Re (Ohms) = 6.2
Le (Mh) = 4.2
Qms = 4.46
Qes = 0.63
Qts = 0.55
Vas (Liters) = 34.8
Sd (cm2) = 460
SPL (db @ 1w/1m) = 86
Xmax (mm) = 14
Woofer Displacement = 0.08 cu. ft. (2.26 liters)
Cutout Diameter = 10.8125 in. (27.46)
Mounting Depth = 6.625 in. (16.83 cm)
Weight Each = 30.6 Lbs. (13.9 kg.)
$500 with the box
These are local pick up only
WILL NOT SHIP
Can also text me too at 315-775-7611
Pick up only. Not shipping.
Have a couple of pics but can get more if someone is interested
Ranalli
Ranalli
Upstate,NY
Ranalli
vegang
vegang
