FOUR 12" T1 D4's
Ranalli
Four 12" D4 Rockford T1's
They are in a box built to Rockford specs.
Was built for S/10 Blazer
All from Big Apple
Nominal Impedance = D4 ohm
Power Handling = 600 watts rms / 1200 watts max
Voice Coil = 3" anodized aluminum
Magnet Weight = 124 oz. Double Stacked
Speaker Connector = Duel 8 AWG Slot Load
Fs (Hz) = 33
Re (Ohms) = 6.2
Le (Mh) = 4.2
Qms = 4.46
Qes = 0.63
Qts = 0.55
Vas (Liters) = 34.8
Sd (cm2) = 460
SPL (db @ 1w/1m) = 86
Xmax (mm) = 14
Woofer Displacement = 0.08 cu. ft. (2.26 liters)
Cutout Diameter = 10.8125 in. (27.46)
Mounting Depth = 6.625 in. (16.83 cm)
Weight Each = 30.6 Lbs. (13.9 kg.)
$500 with the box
These are local pick up only
WILL NOT SHIP
Can also text me too at 315-775-7611
Pick up only. Not shipping.
Have a couple of pics but can get more if someone is interested
Been trying to change title and it wont let in to edit post. These subs D2's not D4's incase some is interested. when I baught them in the box I was told they where d4's and I thaught I was wired at 2 ohm but upon pulling the subs to send someone pictures found out they where d2's so I was wired at 1 ohm. Cant edit for sum reason.
Ranalli
Ranalli
Upstate,NY
Ranalli
