Four 12" subwoofers...
raven15
I need a ported box design for four 12" directed studios... they will be ran by a 2400d directed amplifier 2400watts @ 2ohm... the box will be going in a blazer.. the measurement of the back is about 36"x36" if someone could please make me a design i got the wood ready i just need a design... Thanks!
Alright. I think the outer dimensions of the box should 36"x36"x18". Make separate chambers for each subwoofer. Assuming that you will be using 3/4" MDF, the internal dimensions of each chamber should be 16.875"x16.875"x16.5". This will make each chamber 2.72 cu.ft.
Personally, I think you should use tube ports. PVC pipe works great. If you were to use 3.5" PVC for the ports, you'd need to make each port:
8" to be tuned at 30Hz
7.4" to be tuned at 31Hz
6.75" to be tuned at 32Hz
6.2" to be tuned at 33Hz
5.7" to be tuned at 34Hz
5.2" to be tuned at 35Hz
Well you get the idea...
If you want it to be tuned higher then that let me know. I'll get you the figures.
Hope this helps... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i would really like to use slot port is there a way i can use it? thanks for help!
If you don't have many tools then I think the tube ports would be easier.
word.
round ports = teh ghey unless they're aero ports.
and a huge slot port is just dead sexxxxay //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
EDIT: wow that really contradicted what i quoted.
man 16 hour days 7 days a week are getting to me
raven15
raven15
michigan
raven15
