Ford explore owners
I bought a roll of foam weather strip and went around on top of the weather strip that's in there. Mine no longer rattles. Cheap simple fix. If u have a monster in ur back area u may want to wall though.
were did you buy it
What year Explorer?
ref=sr_1_12
Thats similar to kind i used on mine as well....my mini hatch would rattle insanely....i put this between it and main hatch
What year Explorer?
ref=sr_1_12
99 sport so I have to deal with the rear and side windows
911
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
d77543020
d77543020
stockton ca
Boomsday
