For Trade: Lanzar Opti2000d
sxpimpin
bishes aint shiiiz
Up for trade is one Lanzar Opti2000d.
This amp does rated power if not a little more: 2000rms @ .5ohm, 1600rms @ 1ohm, and about 1100 @ 2 ohms. Cosmetically I'll say 7.5-8 out of 10. Has a couple scratch from bein moved around. Mechanically, Just repaired(popped resistor on the outputs) and works great now.
I'm looking for an amp that will put out about the same power at one ohm. Or a pair of small 1000 watt mono blocks would do. I'm switching up subs so I will no longer have a .5 load and I'd like to get the most outta the amp I'm gonna use.
I'm looking for something along the lines of Hifonics Bxi2006d, mmats d300hc, concept 2400d...ect..
If its for two mono's im thinkin a pair of Bxi1206's, old bx1000d's, jbl 1200.1's...ect
Just let me know what you have as far as MONO amps go..I'm open to anything so let me know what you got.
Let me look around for a pic, I might have one on my computer.
If not i'll have to find a camera to take some.
Maybe if it was a 3000db.... the 2400db is alot weaker than the opti.
Yep its a stong amp..
Stronger than the MTX..//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty:
Hit me up in a PM we might be able to work out some type of a trade...
Yea but I guarentee you you'll get smoke daily at .5ohm with the MTX. At one ohm there about the same, but where it puts out rated power it cannot hang with the opti2000d. I just installed an 8100d in my buddys jeep on two of the T3 TSS 12's
sxpimpin
bishes aint shiiiz
sxpimpin
pensacola,FL
sxpimpin
