yacob.naif
DLP's work exactly like an LCD
in fact, deinterlacing is even MORE important with a DLP, since bad deinterlacing can intensify the rainbow effect
and whoever said HDTV projectors cost 4 grand is insane
you can get a WXGA projector with 3000:1 contrast for under 2 grand
the panasonic WXGA is around $1900 and i believe you can buy them through costco, which means free lifetime warranty............
IMO, a projector's the way to go. Easiest to make room for, easiest to move, best size:$ ratio, and not to mention, with improvements in front projection DLP colorwheel speeds, and the advances in LCD contrast ratios (dynamic shaping lense and bulb iris') the picture is **** near as good as a plasma or an LCD.
in your case, tho, i'd give this guy a call before you did anything about that CRT:
http://atlanta.craigslist.org/ele/192657162.html
