Understanding how everything is affected by your car and other surroundings is key. As for you main questions. Your goal should be a very flat response curve.
Many people have had luck with Infinite Baffle for complimenting their other stages. Some even have good luck with Trunk Baffle.
Though I do not have a SQ setup' date=' I consider my system SQL. I've accomplished this on a budget and am happy with the results.
Though sealed boxes are usually rec'd over ported boxes for SQ, I've moticed that I am finding more luck with a box tuned relatively low (30-32) hz to accompany my front stage.
Amps that deliver a clean and stable power supply will naturally sound better than amps throwing dirty power that can have spikes.
I strongly believe in somewhat transient and transparent lows, with everything becoming more detailed and punchy with rising frequencies.
Obviously deadening and proper wiring and electrical will be mentioned.
Imaging is crucial. Speaker placement, time alignment, x-overs all play a very important role in your listening experience. I try to limit the amount of reflections a sound wave goes through before reaching my ears.
Hope this helps.
Feel free to disagree with anything I've said, or promote anything I've said.[/quote']
Thank you for taking your time to reply to my post with an intelligent thought out response. This is exactly what I'm looking for. My builds in the past have pretty much all been build around my "sub stage" I wanted my bass to just hella beat and didn't care about much else but it got old after a while. Switching from rap to to any other genre and my system lacked horribly.
I now want a system that is "well rounded" I don't really listen to rap anymore so I need pointers from people with experience.. I love my country music and 80's rock //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif So I'm looking to build a system up that can handle my taste of music. I've grown out of "rap"
So pretty much what I'm gathering is that I need to make sure my components are mounted in a solid location. I have abs plastic kickpods so I guess I will need to glass them up. My mids will be down in the kick and my tweeters will be in the a pillars (i know this isn't the best but it will have to do for now) I also don't like having tweets down in the kicks because my legs get in the way of the tweeter and makes everything sound weird.
Okay now for sub enclosure....For the most part I'm set on building a solid sealed box with some kind of egg carton looking foam installed behind the sub (inside the closure on the opposite side of the sub) If I'm unhappy with the enclosure I will then rebuild and experiment with different designs.
The subwoofer i will be using isn't the best subwoofer but it's also not the worst out there. As I stated in my opening post there's something about lower power subs with paper cones and foam surrounds that my ears just really like.
I have also ordered 100sq foot of fat mat (i dont think it's going to be enough though) The one thing that I've been unsure about is "ensolite" not sure if I spelled that right but what's the deal with that stuff? Is it really worth the money and if so where should I put it first (will probably have to do it pieces at a time because of the price)? And what brands are the best bang for buck?
Thank you for all those who have contributed to this thread so far, it is greatly appreciated.
