Foam or plastic baffles?
For the baffles that go behind the speakers? Foam all the way; They'll be easier to mod in the event that you don't want them totally sealed, and they'll have way less resonance issues compared to plastic.
Cool. Thanks for the input, Squeak. I read of someone cutting a hole in the back of them, to allow air to flow freely. Any benefits to this? These are going in the factory spots in the door, if it matters. Also, Ill be using a "depth extender" to gain some additional clearance, so Im figuring the baffle will simply go underneath the extender?
Depends on your speakers. Most car audio speakers are designed to play infinite baffle (i.e. no enclosure). Sticking the baffles behind the speaker creates a small encloure, which obviously causes problems if the speaker was designed to play infinite baffle. So, cutting the back or bottom off of the baffle allows the speaker to still be infinite baffle, while still protecting the speaker from water.
Try them sealed (by the baffle) and try them IB and see which way you like better.
On top or underneath....either way should work. Depends on how much depth you have to work with.
I believe they will work in either, but Im not sure whats recommended. Its a set of RE comps, to be powered by an ED 9.4. Ill take your advice, try them both ways. Thanks for the help.
can you use those baffles on a door with roll up windows? my speaker rest against that window bar
thats a questions only u can answer since we cant see ur car, although if its already hitting the window bar then u probably cant fit the baffle in unless u added a spacer
i built a baffle for the doors and placed a spacer-you know im gonna but a pair of these baffles to see if they will work- hell their only $11.00 bucks
zachzchw
zachzchw
ohio
squeak9798
