Flex Issues With A AQ HDC 15
sounds like my blazer. the back door on the drivers side of my blazer flexes bad for some reason but the camera dont pick it up unless im right up on it. i need to get some new youtube vids up myself
I know it's odd and I have a really expensive canon.
I think it's because I have a crappy sd card and it's only like 15mbs per second or whatever.
You are running an AP3k on stock? You think I would be fine with an AQ2200 on stock until my battery gets here?
What ohm load are you running it at and how big is your car's alt. I mean what amperage is it?
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
427
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
got160s?
got160s?
Michigan
plantinseeds
    May 18, 2024
    May 18, 2024
