flat dual inputs
zx_htL-k9Bkf5aqWAQtdUoPa-yC5tcahhNCGip7-jtgjYD-LmzKMckDOQur1NFxfryG3vKuBd1p7fY5hYLEgJJBfPIjvV67g7NVW-AqzhEnh5EBY7t416HMkQGxZxGhbSoQ8IP2tJ1tyC52b3g7PkmkK_XHV4wi4VvtfbZKdBXgi2bnjJ6-SOPhxTlBOWy7Jg3Y0UuQPNXdHDQYx-IcqQds5nEVkYE6L8LeQc7kTKi-j4ifKlDS92vinDFUC0yKY0h1jl4hAQCzq9HmoMJHtoPQpDtbY47SE_ViY_ncm7H0bdt5zbCgMGoSZE0KDWx93h6BHwcS2iXUk9fvRRXAzR6UDagaaKxT5u0rOuncHEwsw-b15Cqd7qpODFwEvVyhSmTY8Rbc6_GMiWPAMWcrGoj5ls20a4bOA7GZWc2CdL2cgmbsrhtsrx_TH_hEnM_B8r1q02AQxAo7vq1FMw2kACn9LyWrxXEFH9fOb0LwRSf0SKK3Uf5gb-DYgMH2q3I29MeOoMcCvxxvnB2Xven2iyg=w720-h406-no
What do y'all think. I have no mill to machine a "proper" dual input. Simply I can tap those holes and use terminals.
If i were going to make something like this, I'd round the bottom of the input into the amp and maybe some sort spot on top for the set screw of the amp to clamp down on better. Other than that, should work.
749
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
761
864
jnk2013
jnk2013
san antonio tx
jnk2013
pfft
    May 1, 2024
pfft
    May 1, 2024
