Flared port help
what does 0hz sounds like is a good question have u ever heard it... idiot .... its for noobs like u to comment on,, 2000lade and when ever u want to go at let me know u might be louder but i sound better lol
SMH @ you bro. I'll respect dude by not dumping all on his thread more than I already have.. so here is this:
NounInflected forms: pl.hertz Abbr. Hz A unit of frequency equal to one cycle per second.
If it's 0 hertz.. there are no cycles.. and/or no sound..
Thank you & come again.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif mobeious = not newb //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Me = not newb //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif:fyi://content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif:fyi://content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
As for teh OP port area question - 2 6" aeros should suffice. Apparently the witch math that's been going around the forum indicates that 1/2 area is needed when using aeros vs slot. So 6.5 cubes x 16 sq in (rec port area per cube) = 117 sq in. 2 6" Aeros = 56.5 sq in, which is roughly half of 117. So 2 will do, but personally, I would use 3 just to be safe. But 2 should be fine.
im just saying if he is going for SQ 2 18's ported is not the way to go and size has alot to do with the way a sub acts heavier cone (18") cant move as fast as a lighter cone(10)
It also depends on what the cone material is etc, I listen to rap and hip hop mostly and I also stated that I am looking for low low distortion subs with a long throw, the linear coil will help hit the deeper notes with greater accuracy so please answer my question and not get all over my case cause i stated that im looking for some SQ in my sub stage. If i was going for an SQ set up i would be running an active substage and line sources in my A pillars...
Agreed.
Also, if you're in need of custom 6" aeros, I make them. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
no shit 0hz = no cycles that was the point of putting it on there
You put an apparently easily answered question on your headline.. o........... k.......... ? Yeeeeah. Anyway..
oh i forgot they started runnin subs on passive crossovers lol .... ill get out of this post for ya lol
what does is matter runnin 1 sub or 2 subs for SQ
with more subs you can have each sub play a diff frequency range, they would have to be diff size subs, I had the chance to listen to a multi sub - substage at TC sounds, and it was amazing...
photocrazy8
Probably doesn't like you
photocrazy8
CA
IgnoreMe
vegang
vegang
