Flared Port Flare Diameter
xluben
Thanks!
I was guessing aroung 7" for the Precision Ports, but I was hoping the Dayton was a bit smaller.
I am thinking of using two 4" dia 17" long flared ports (Precision or Dayton), and if the flare diameter is 6" I think I can fit both of them and the subs on the front baffle of the box, but if they're that wide I don't think I can.
What are the possible adverse effects of putting the ports on the side of the box?
Do you think I'll get port noise with 2, 12's in a 3 ft^3 combined net box tuned to 33Hz? According to WinISD I only get 14.6 m/s max air velocity in the port which is less than 17.5 m/s, so I should be OK, but I was hoping someone with real-world experience could confirm this.
Thanks!
You can trim the mounting flange a little.... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Is it really bad to mount the ports on the side of the box?
Because even if I can fit it all on the baffle, I'll still have to use 90 degree elbows to fit the ports in that direction. If I put the ports on the side I should be able to do 17" straight as long as they don't get in the way of the drivers.
It works for TCAB //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yeah, not externally
But what's better:
straight ports on the side of the box (easy)
or
ports on front baffle w/90 degree elbow inside box (PITA, more expensive)
It's going in the trunk of a 1999 Honda Accord. If I were to do the side ports I'd probably fire them towards the passenger side, unless the driver's side would be louder.
Also, I have tried firing my subs up and they weren't nearly as loud as firing back towards the tail lights.
xluben
xluben
Minneapolis, MN
TooLowTooGo
