First Ported Build?
GMCbeat
I'm planning on building my first ported box soon. It will be for 3 jl 12w1s. I plan on making it a slot port about 4.7 cubes at 28hz. My question is about port area. The design I have now has about 74in of port area. Would that work or will I end up with port noise? More? Less? I'm still learning about designing enclosures so anything else I should consider? First post, BTW. Thanks.
if you need a box design.. there are great members in here that do great job...to start out with ill say member -PIONEER~SATURN- he is the man for box designs...if interested you should hit him up..
also welcome to the forum...
Thanks, so far what I have is an L-port 4" wide 18.5" tall 11.25" deep and 25" long. Overall the box will be 45" long 20" high and 16" deep. Going in a GMC Jimmy. Box is for 3 12w1s. Any problems with this?
your car is a SUV i believe?..and you said ported right?..it sounds good to me..
EDIT:i think my box is 45 long also...i only have a 15 ported @30hz...it gets loud and low!!...
He is building me a box right "(edit) now" and doin a great job
:veryhapp:here is the build:veryhapp:
to...http://www.caraudio.com/forum/showthread.php?t=385286
What are you doing with them, subs up port back?
Good to see another guy from the bay area on here.
No, since its my first build I'm just going to keep it simple. Subs and port back. Eventually I'll probably go to sub up port back but that will probably be with some better subs.
GMCbeat
GMCbeat
Clearwater, FL
rmzsuzuki89
