pervertatoid
Okay, I had a couple of ideas that would be great for my subs in a fiberglass enclosure. Unfortunately, There's no way that I can get these designs in and out of my trunk during or after the build process.
So a couple of questions: Are there any tricks for building a fiberglass enclosure in separate pieces (or something otherwise) so that I could get it all into the trunk?
If not, are there any tips on how to completely build a box in the trunk? Stretching fabric while inside the trunk seems like it would be quite difficult if not impossible, not to mention applying resin to the sides which would fit into the widest opening of the trunk.
If I'm pretty much S.O.L. with this design, how much worse is it going to be to have two separate enclosures on each side of my trunk facing (roughly) inward? I've read on here that separate enclosures cause issues as cancellation and distortion; I don't want my SQ to suffer significantly.
Thanks in advance!
Thanks in advance!
