Firewall grommet
I created my own hole on the pass side above the carpet below the heater box. If you do this method drill EXACTLY where I did or slightly higher so it is accessible on the outside.
This is what I just did on my wifes 95 accord. Keep in mind I ran 1/0 and 4 gauge through that and to create the hole I made 2 over lapping holes with a unibit. It's fugly but it works I cut up a JL dustcap and created the shield around the cable and I with either go in with a little bit of great stuff or some Rope caulk to seal out the air/moisture
rseigle
rseigle
Louisville, KY
truckramrod
