Finishing layer
terra
Bondo'd my box and got it all sanded down very smooth. im putting on primer next before paint but my question is what kind of primer? like..primer in a spray can? or primer for walls? home depot kinda primer? what should i be using here?
spray can is fine and will lay on smoother. What you using for final coat/finish?
I just did some med gray fleckstone with a clear coat and it looks pimp as hell. And NO crazy sanding like gloss black...
im doing a maroon glossy top coat with several coats of lacquer after that. so primer in a can will give me the best surface? sounds good thanks
terra
terra
Yes
terra
