Finding new engine ground
ten_ton_bass
I am in the midst of doing the big three and I just realized there is no way in hell I am getting down to my factory engine ground. Even if I could the bolt on it is WAY too big for my ring terminal.
So I need to find a new engine ground. Any suggestions on a good place?
Also is having the 2 grounds gonna screw with the car?
You could always test different spots with a dmm. Just use the battery positive and you should be able to get a voltage reading when you put the negative probe where you want to ground it. Youre definitely going to need sand paper as well
All done and WOW!! What a difference! Its as loud with my remote knob half way up as it used to be with it fully cranked.
I will see later tonight if my headlights still dim but so far I am very happy!
ten_ton_bass
ten_ton_bass
Lacrosse, WI
Below20hzonly
